Feature request - MAP/EMAP efficiency load
When using an EMAP sensor on a turbocharged engine, it makes sense to use MAP/EMAP as the efficiency load, as it gives a good representation of the real VE, without having to add in correction tables for exhaust back pressure.
It’s possibly at the moment by adding the calculation as a number field and setting the load axis manually, but it would be nice to see this as a preset option alongside MAP/Baro etc.
