Tyco Relay as Kill Sw and PMU
Searched far and wide but did not find anything regarding correct or rather safe way to wire in a Tyco/TE high current relay as a battery isolator along with PMU.
Long story short, had a runaway engine, kill switch was used at around 4,5k rpm, ADU displayed “PMU overcurrent” error and PMU got fried. No fuses were tripped. As far as I can tell, power distribution is as in the image bellow, there is a 5A fuse between Relay Pin87 and PMU ignition sw input (image at bottom of the post, hand drawn).
This got me questioning what is the correct way to do it with a high current relay so alternator load dump does not fry anything.
I always followed the motec guide for wiring and simply setup a master switch as a condition for every output. Works and kills the engine but never tried activating the master switch under non-idle conditions. (Bellow the hand drawn diagram)
But then I realized that motec does not have a wake-up/ignition sw input and ECU Master Battery Isolator shows the kill signal going to PMU ignition sw input.
Any input is greatly appreciated.
You need to drain current form alternator . For all relay isolateor we use spike protector with tvs diode. Have a look on wiring of manual battery isolators with 2 big and 4 small terminals when you turn it off current form alternaoer is drained to ground via big ceramic resistor. That typical installation error.
I understand the need for load dump protection and ways to achieve that. I always use a TVS for installations with no PMU but it’s my understanding the PMU has an internal TVS, hence the operating voltage description: 6-22V, immunity to transients according to ISO 7637. I haven’t actually purchased the ISO but it does deal with load dump among other things. Tyco relay has load dump test data referencing the same ISO.
Could You share some sollutions according to load dump protection? All TVS diodes I search are for PCB mounting. Can’t find anything with stud mount.
I also think about TYCO “change over” type relay and wired it with heat resistor to reduce load dump after disconnecting battery.
Here we have a ready kit
