Looking for advice on how to get my EDL-1 and Function 2 for delayed turn off operational since upgrading to V3. Both were functional before the software update. I did use a new SD card formatted to fat32 from the list updated to the v1.21 software. I supplied a link of my tune. The vehicles an ā05 Lotus Elise. Thanks in advance.
silverbullet.emub3 (74.5 KB)
What is the problem with the EDL ? Doesnt logging to SD Card ?
What is a problem with the delayed turn off ? Your logic (FN2) seems to be correct.
The delayed turno off function is disabled in your base map (but I assume you have tested it as it is properly set up).
Thank you for your response, I turned the delay off because it either permanently keeps the ecu powered or turns off at the seconds entered depending on the invert selection of F2. It will not use F2 for its delay. As far as the EDL-1 the ECU will not see a connection other than verify the time was correctly set. For that I went as far to rewire it using both connections (RX to TX) with no change. The green light stays solid, amber light flashes blue when inserting the card but no logging happens.
For EDL open EDL log group:
There are be 2 reason that it doesnt work:
Swapped tx with rx
Not upgraded firwmare or old firmware. Please use the latest 1.22 https://www.ecumaster.com/files/EDL/VERSION_1_22.zip
I will take a look for delayed turn off
Function in delayed turn off wokrs backward. If it is false the power is kept, when true the power is cut.
In next build there will be additional option: Keep power when function TRUE and Keep power when function FALSE.
Thank you, got the EDL working with the 1.22 software. Still working on the delayed turn off but not a big deal. I appreciate the work you guys do.
