V3 base maps for 1jz
Hi .
is there any V3 basemap for toyota jzx110/jzx171 ? when open v3 studio and base maps , theres only 2 audi on one ford maps.
strugling to get any good idle strategy . DBW /idle /vvti cam setups for stock car.
got auto trans so can not go full race mode
or can someone share some map where is some good starting point.
thanks
there are around 15 2JZ base maps available for V2.
Import one to V3/Vision thats closest to your setup and see if they can work for you.
configure and edit your inputs/outputs etc. to suit your application/layout and go from there.
Thanks.
I have done that , but idle strategy is different in V2 and V3 . That’s what I’m struggling.
I’m using stock ECU parallel to controlling auto trans so dbw, iddle,cam and torgue strategy settings need to be right to begin
Ok. Understood.
have a similar issue with V3 on the E36 M3.
Idk how this works on your particular setup but with my auto IS300, idle speed (basically all IDLE stuff) was controlled by the stock ECU. The EMU had zero control over it. The only thing the EMU could control was idle ignition correction. So no matter what you put into the idle tables/parameters, nothing will happen to your idling. UNLESS you have the throttle body wired up directly to the EMU.
Yep this is what I did have firsts.
Now I want to get more out of this ECU.
I want to get cruise, AC , launch control, etc working.
And now , yes this is when throttle is controlled by emu.
Hope to find some good starting point .
We can not be first to try to make stock ish car to work with V3 .
And before someone says, yes I will get car tuned but want to get car well driving before get there.
So if there is someone with stock throttle and willing to share settings or knowing good basemap to use
Thanks for everyone who reads and answer to this
su 16. elok. 2026 klo 4.42 Knownworldwide <notifications@ecumaster.discoursemail.com> kirjoitti:
