Convert v2 file
Is there anyone that can migrate v2 to v3 for me? Of course a payment will be offered. The car is 3.2 VR6 and has completely running v2 file now. After the import there are few stuff to be fixed, based by the logs:
  • TPS & PPS config - just calibration, will do it
  • No “batch all injectors during cranking” → In V3, cranking fuel is calculated from VE tables, not raw injector pulse width
  • Cranking airflow table → You must define throttle opening vs coolant temp for DBW engines
  • ASE strategy changed → V3 splits ASE1/ASE2 logic differently
  • Accel enrichment → V2 accel settings don’t transfer. You must set up acceleration enrichment manually in Fuel → Accel enrich
These are parts of the log that I have seen. So is there anyone willing to do it? I can send the v2 file
There is a BUB base map for V3 included with the EMU V3 software.
You can use it and then just copy your specific values.
Is it possible to do it for me based on my v2 file? I am very unsure in my abilities
You should open your v2 in one window. The base map V3 in another window. And compare every parameter.
I’ve did it for my lotus with a base map and was able to achieve near 90% of everything.
you will have to tune VE anyway so it is better if you understand the whole thing.
I can share you a picture I’ve created to learn the difference between v2 and v3
