V3 software and Haltech GPS sensor HT-011310
I need to connect a GPS speed sensor into the ECU, its a Halltech GPS , output is 5000 pulses per KM. How would i do this in the VSS settings?
Presuming its in the ratio settings?
Are you sure the pulse number ? 5khz is per km/h is extreamly high value
Notes: Calibration: 5000ppk (5000 pulses per km), Use with SPI or DPI ECU Inputs, GPS update Rate 10Hz, High Accuracy 0.3% Deviation, Pulse Compensation in tunnel, Anti GPS Drift technology
Cut paste from the site.
I think it is just a matter of proper multiplier if you connect it to vss input
I’ll install soon, test, and feedback.
