Device loads and works fine in Light Client. Switches and rotary controls respond correctly.
Firmware shows as both 3.0.
Tried to add CANX file in ADU. Receive 2 or 3 errors as shown in photos. Switches do not respond.
Same messages received when deleting from ADU.
Any ideas?
Found the answer - remove all channels that are not needed from logging.
By default, the configuration includes several PMUs which I can recommend to remove (I think it also contains an EMU black). If you don’t aggressively prune the default configuration about 650 bytes out of the 1024 are already used.
