Hi community, I am rewiring my Westfield Mega S2000 (Honda S2000 engine, 2005 F20c) with the PMU24, ADU 7, Keypad 13 & 2 rotary switches, and EMU black, progess is going well and now onto the bits I am unsure about. The alterator is only has 2 wires in use with the old Omex ECU, 12V ignition and warning light.
How best to wire this in now,
- 12V from the PMU when the the ignition on button is pressed on the keypad
- warning light - should this be an aux input to light up a warning light on the adu via canbus but I think the output is 12v?
- I have already set up a warning in the display to come up when the battery voltage is low.
any advise will be a help.
Phil
