Hey everyone,
I’m working on a 1994 JZA80 Supra with a 2JZ-GE non-VVTi using the factory distributor and igniter, running an ECUMaster EMU Black on V3 software.
Current issue:
No spark from the igniter
BUT I do see spark count / ignition activity in the EMU software
Setup Details
Factory Toyota ECU wiring:
Pin 57 – Red/White – IGT (ignition trigger)
Pin 58 – Red/Yellow – IGF (feedback)
Pin 27 – Black – NE (crank signal)
Pin 26 – G1 (cam sync)
Pin 25 – G2 (cam sync)
Pin 77 – STA (starter signal)
Current EMU Black wiring:
Ignition Output 1 → Toyota pin 57 (IGT, Red/White)
Primary trigger → Toyota pin 27 (NE)
Cam sync → G1 / G2
IGF (pin 58) not used
STA (pin 77) not currently used
Current Behavior
ECU powers on normally
RPM is detected
Sync is detected
Spark count is visible in software (so ECU is calculating ignition events)
No physical spark at the igniter / coil
Problem
Even though the ECU is clearly calculating ignition (spark count visible), there is:
No output at the igniter (no spark at all)
Questions
Is Toyota pin 57 (IGT) correctly wired to EMU Black Ignition Output 1 for distributor setups?
Should IGF (pin 58) be connected to anything on EMU, or left floating?
Is STA (pin 77) required for proper ignition output during cranking?
What is the correct configuration for:
Spark distribution (Distributor vs other modes)
Coil type (with built-in amplifier vs other)
Trigger edge settings for NE / G signals
Has anyone successfully run a 2JZ-GE distributor on EMU Black V3 and can confirm working settings?
Note
I’m new on here so I can’t upload my tune file or screenshots yet, but I can provide any values or settings manually if needed.
Any help from someone who has done a 2JZ-GE distributor setup on EMU Black would be hugely appreciated.
Thanks.
