EMU BLACK: Voltage discrepancies and no spark condition
Hi there,
I have a 2jzgte with D585 LQ9 coils on my is300. I have wired everything as should, running wasted spark setup, including the following coil-related pin:
12V Switched (Red wires) - Gray Connector Pin 18
Power Ground (Black Wires) - Gray Connector Pin 17
Sensor Ground (Brown Wires) - Black Connector Pin 39
Coils 1&6 (Purple and white wires) - Gray Connector Pin 8
Coils 2&5 (Pink and Blue wires) - Gray Connector Pin 16
Coils 3&4 (Green and yellow wires) - Gray Connector Pin 9
I have no spark at the coils.
Battery voltage checks out at 12.34V
Output voltage Gray Connector Pin 18 is just measuring 0.112V for some reason.
I do the same test at the plug where the cables plug into the coil connector and i get the same 0.112V so continuity checks out.
Any ideas/settings I should be changing? I am using the base map provided in the website for a vvti 2jzgte and everything looks pretty straight forward I’d say.
Any leads or ideas will be greatly appreciated as i continue to troubleshoot.
Thank you,
Daniel
I’m not sure if i understood u correctly but G18 12V switched isn’t a output pin…u need to put 12V there to turn on emu = KL15. So clear that u don’t measure anything there.
I think he meant that he connectd a switched 12V from ignition lock to G18.
