2jz-ge-nat cam #2
On my 2JZ-GE-NAT, I have a VR sensor on both cams. On my EMU Classic, I have one wired to Black-15 and one to Black-06. Do I need to configure Cam#2 in EMU software?
Thanks,
Bruce
It is not necessary to use both cam sync signals, but if you already have them connected, you can use this to achieve faster synchronization and quicker engine startup.
In CAN #2, select the 1/2 2JZ second cam trigger type.
Artur,
Thanks for getting back. I appreciate the feedback. I am running the EMU classic and do not have the 1/2 2JZ option for CAM #2.
Bruce
You don’t need to use both cam sensors. Just use one and it will work just fine.
