hello everyone, im having some issues with possible software and hopefully not mechanical issues.
the run down on my setup…
ecu classic
2jz gte non vvti
cam trigger sync keeps dropping.
battery voltage lowers .30vdc when it happens
cam trigger goes from 24 to 23 to 1 within the event it drops. tps and other map sensors don’t dip either when it happens. only the cam trigger signal. it says it’s sync’d though
entire harness just got replaced so i know it’s not a wiring issue anymore. it has 2 brand new denso cam sensors and a denso crank sensor. as well.
idk if there’s something missing in the software i’m doing wrong that’s causing the blip during drives.
here is a photo of my trigger settings and everything that may be associated with it.
