A cylinder often misfires
In today’s test, during operation at 6500rpm, one cylinder frequently misfired (the air-fuel ratio suddenly increased). I tried to replace the ignition coil and spark plug, and also tried to adjust the ignition Angle, but this phenomenon still occurs. In the operation process, it is normal for a period of time, but it will suddenly happen, and the reduction of speed can not be alleviated, and can only be stopped and restarted. Ask each senior, how should I check?
2025_0330_2012.emuprolog (669.5 KB)
Be on fire.emupro (27.4 KB)
