Hi all,
Started tuning my emu pro 8 today with the intention of doing some mapping on the road today.
I ran into a strange misfire problem though.
Engine is a 2jz-GE VVTI na-t running the OEM VR cam and crank sensors (both new, engine got a full refresh)
Some background: I run the whifbitz R35 COP kit, when I recieved the kit It had harness issues right away, the 12V pin in connector 6 wasnt crimped on, giving me a dead coil. Found that, fixed it.
I still seem to get misfires though, the standalone shows coil 3 and 6 have increased dwell times and the spark plugs show that these coils are misfiring. Swapping over the coils between each other does not remedy the issue or move the issue to the other cilinders. It remains in 3 and 6. Replacing or swapping over spark plugs also does nothing.
Given the firing order of the 2jz, 3 and 6 fire together, so I also have a suspicion towards signal or trigger distortion of some kind, but im stuck in finding a fix right now…
21-10-2024.emupro (25.9 KB)
2024_1021_1125.emuprolog (5.0 MB)
IDLE_scope_2024_1021_1131.emuproscp (3.0 KB)
RPM_scope_2024_1021_1131.emuproscp (2.9 KB)
4000RPM_2024_1021_1136.emuprolog (6.6 MB)
Coil3&6_2024_1021_1716.emuprolog (1.7 MB)
Coil3&6_dwelltime_2024_1021_1743.emuprolog (1.5 MB)
