I’m currently running without a cam sensor. I’ve added a sensor and now wondering how difficult it would be for the ECU to recognize it. The sensor is connected but the Oscilloscope on the ECU doesn’t see the Cam. It sees the Crank Position Sensor. Any help is appreciated. Tony
Have you set up the secondary trigger parameters?
Also will help if you share the project. this helps to look if the settings are plausible
Thanks for the response. I have looked at the parameters and it’s a bit much for me. I’ve had little experience with software. I had a tuner install this unit. I’m running a 2.0L VW Jetta engine with ADU display. The tuner is hard to get a hold of so I’m on my own for now. My expertise is mechanical, so software is a struggle. Tony
No worries Tony, thats why we have the community to help you out ![]()
Is it possible that you can save the project file and upload it to the forum here?
you can upload using the button highlighted below ![]()
Ok very good I’ll give it a try tomorrow. Thanks
I believe this is the project file containing the program. Let me know if you are able to open it.
The engine is a Jetta 16v 2.0L .
Thanks. Tony
pre cam position sensor.emub (144.6 KB)
Hi shyam when I enter this parameter, what do I expect next? Is there another step required? Should I see a pulse on the oscilloscope coming from the Cam Position Sensor?
I was able to solve the problem with tips from here and Andre from: Custom Wiring Solutions. My VW Rabbit is running much better with the Cam Position Sensor now in play. Thanks. Tony
