Duratec V6 secondary trigger
Dear All,
I need your help with secondary trigger.
I have v6 Duratec engine (aj30) from Jaguar S-type (2000).
After setup of emu black, we can not detect secondary trigger during the cranking stage.
All wires connected correctly, all wires shielded, grounded properly. VR sensors pinned according to manufacturer (Jaguar) signal and ground in the correct position.
After swapping wires between Cam1 (secondary trigger) and Cam2 situation is exactly the same. I only can see Cam2 but no secondary trigger.
Additionally, everything well operating then engine is running, no issue with signal detection, trigger pattern looks very good.
Both cams has 4 teeth Y shape with extra tooth between V.
Any thoughts what could be wrong?
P.s. battery well charged, during cranking shows 9,5V.
Have tested with more powerful battery, result is the same.
P.s.s. I use medium or high noise filtration otherwise crank, cam sensors catch a lot of signal noise during the cranking.
Hi
could you please share your project with logs and scope logs? This will help to analyse further
and do you mean when the engine is running you see signal from both the cams? :thinking:
and during cranking is it only CAM 1 ? or CAM 2 also?
Yes, when engine is running I can see both cams, because I’m using option ‘sync as soon as CAM is decoded’
Im am searching for an Map to configure an Jaguar S-Type Motor V6 3l 240hp
Do you can help me ?
Thank You
Hi Joe,
Sure! Do you have stock engine?
Br,
Romas
Yes it is an Stock engine in an other chassis
Thx
Joe
In my case the map is heavily changed from the stock as I use ITBs (Alpha n map), the secondary trigger is trimmed to one tooth, not the original pattern.
I will upload later today my map and also one more map which is Rocketeer swap (more similar to stock engine).
Br,
Romas
Thank you very much
Joe
Good day,
Will you post the file in this chat or would you prefer to send it to me via email?
Best regards
Joe
I wanted to ask if it's possible to have the map sent to me. I have a race coming up with the vehicle, and unfortunately, I can't program it.
Thank you very much.
Joe
Hi Joe,
Sorry for late reply. Please find attached zip files.
Br,
Romas
(attachments)
FInal Tune, 10-10-23.zip (17.2 KB)
Please provide your email so I can directly send it to you.
Br,
Romas
Thank you !
here is my mail : schuh1994@gmail.com
Tks
Joe
