Additional vehicle CAN stream
About CAN Streams
EmuBlack V3 has a CAN stream for 997.1, but will it also be available in the Pro version?
We discussed this topic previously when we talked about V3.
Specifying the bits on the CAN transmission side is a bit difficult, so it would be great if it could be provided as a CAN stream.
I currently own EmuPro 8 and am considering installing it on my 98721 Cayman S.
Since it’s not a racing car, it needs to integrate with the existing system.
Currently, the CRCRolling counter outputs the same data as the acquired factory CAN stream.
No progress has been made yet regarding the water temperature data stream.
Thank you.
EMU Pro can import .dbc files. This could get you started
If all you need to emulate is the dme, just pick and choose which ones from the list during import.
I had no idea such a complete DBC file existed. It is truly amazing.
Thank you; I plan to test it right away after swapping the engine.
