AFR value instead of lamda
hello, how can you display afr instead of lamda value on the adu?
i tried using channel ecu.afr1 but does not work.
any insight please?
Make a new table in the project tree.
Use the channel name “t_AFR” to display the value.
Thank you will give it a try.
I’ve just tried this to get an AFR gauge working, previously pulling from ecu.AFR, and upon pressing OK after completing the table it comes up with the “too much data…1008 bytes” warning.
Is this ok?
edit. When it comes to displaying it on a gauge on the ADU, will I need to create a number/conversion or will the table posted previously in this thread handle that itself?
Thank you :slight_smile:
You are logging too much data.
You need to lower the frequency or disable some channels.
You can do it in the “Logged channels” panel (press F8).
The table alone is enough.
You use the value from the table as the AFR channel.
