AFR not changing
Hello, I have an emu black and installed a wideband 4.9 to go along with it i also got the bti can gauge. I wired everything correctly and the gauge turns on but the value for the afr does not change, it stays at a steady 14.8, even in the emu black software it stays at 14.8. i have my 02 sensor setup as the wideband option and still nothing. is there another step that im missing in setting it up? thanks.
Hello, first of all, the LSU probe needs time to work. It doesn’t work straight away. You can change the LSU probe settings so that it heats up faster, ie after ignition and not when the engine starts. And then you should see the AFR indication. But later change the setting because it quickly destroys the probe. And check the logbook to see if you have an LSU lambda probe error.
