Audi 18t bam DBW_TPS_PPS V3 0.48
Guys need help can someone look at my file .Car idle and drives perfect but coming to a stand still the car dies. I looked at all possable values .Clearly i am doing something wrong
Is it normal for the DBW dc out to drop that far ?
20250507_1411.emublog3 (38.2 KB)
DBW.emub3 (67.0 KB)
Just an update:
The issue was related to the IDLE airflow system settings. I disabled the actuator and increased the idle speed to 950 RPM — the engine no longer stalled after that. I then re-enabled the actuator and checked the arm state airflow table. After adjusting both the idle settings and the table values, the stalling issue has been resolved.
Hey, Im having similar issues with the engine stalling when goming into stop, could you share your map with the new settings which is working for you?
Sorry bud only seeing this now ,
EMu black to upload 28_05_2025.emub3 (66.9 KB)
