Hello all , Loving the v3 and looking for some base Parameters for Cycling Idle ,rotational idle for a 1jz non vvti with no IACV or DBW . Is it possible ? If so what steps should I take ? Car also has a 90mm Throttle body and custom intake that might throw a curve ball. I would like to have aggressive idle sound short of buying cams . Thank you in advance
v3 . I’m sure someone would have starting parameters please.
You can’t really do cyclic idlw without iacv or DBW, or you have to enable it permanently and set your base idle way higher
Have it on Push button Switch . I thought a good tuner would be able to do this without DBW or IACV Through Ignition and fuel ?
You need to provide addition air.
So if you dont have DBW or IACV then you need to open the throttle to get for example 3000 RPM and then set up Cycling idle (always active) or use Idle Spark / Fuel cut strategy.
