Request: Rotational idle implementation
Is there any plan for a rotational idle implementation for the Pro? I have read that the Black V3 software has this functionality.
I have implemented a similar functionality using the rev limiter tables, idle control tables, and a couple custom functions, but, the cylinder cut rev limiter doesn’t work perfectly for this function. For example, if set to 50% cylinder cut, one bank is disabled constantly. If I set to 49.5% or 50.5%, the cylinder cut switches bank to bank on a slow time scale.
It would be have an option for either:
a) dedicated rotational idle functionality
b) finer control over the cylinder cut algorithm to control or rotate which cylinders are cut on a faster time scale
Or, if I am missing a way to achieve this with the current settings, please let me know!
Thanks!
Example of my current implementation (1/3)
Example of my current implementation (2/3)
Example of my current implementation (3/3)
Hi, any feedback? Is anything like this planned?
No is a fine answer, but it would be helpful to know what to expect for the future.
We want to implement this, but we can’t provide a timeline at this time.
I appreciate the response, perfect, thank you!
