Battery isolator CAN messages
Is it possible to get the Battery Isolator voltage through a CANbus message?
I would like to use the voltage detected at the battery isolator to control the charging function of my ECU. It would use the voltage at the isolator to send a duty cycle output to the alternator.
Yes, you can export the DBC in LightClient for isolator messaging.
With isolator loaded or live, be sure its selected and click more. There you can find the export options.
That is brilliant! Gonna try it now. Thanks!
