Help converting Canx file to dbc
Anyone know how to either export or convert the Ecumaster Canx file to a DBC file? Trying to setup another module to recieve messages, but it only imports DBC format Canbus format file.
Which file would you like to convert?
We might have a DBC version available.
Initially it was just a simple file exporting RPM, Throttle and brake data, but I will be doing Flagtronic Data during the off season.
OK, so you want to save a DBC from one of our devices and use the DBC signals with a third-party device. Do I understand this correctly?
From which of our devices do you want to transmit data to the third-party device?
My initial project only had 3 pieces of data being output, so not a big deal to reproduce, but future I will have more data to output.
I’m outputting from the ADU, that data is then being read by a VBOX video recorder, which can import .DBC, .VCI or .REF (the last two appear to be VBOX format)
The best solution would be to add a button to save a DBC file directly from ADU.
We will add it in the future.
have you implemented this feature? We’re starting to work on a rally raid vehicle, and we’ll need to export some CAN messages. I’d like to know how to convert the CAN output message directly to .dbc.
thanks in advance
is this possible yet @Jan_Matlag_ECUMASTER I will need to do this next week on a PMU.
