Keen for some opinions on the best method to set up V3 for switchable idle targets.
The goal here, is to have a switch on the dash that raises the idle target to 2700 RPM. (DBW setup, no IACV)
In V3 I’ve tried using:
- custom idle modifier table (unreliable results)
- AC idle up function (can’t raise rpm high enough)
- Clutch switch function and closed loop (no active idle control, which I want)
- Clutch switch target (can’t raise RPM high enough)
Configuration attached below… any ideas?
