Bit combine + compound can transmit
Hello there.
We have never used the ADU dashes before, so I have a few doubts.
Is there any way to transmit compound messages?
What about the bit combine function (we usually used that on motec C1xx dash), it is available with some other name?
Can you explain what you are trying to do?
The ADU/PMU/Pro can do multiplexed messages, so same address with a counter on the first byte. Like the Link protocol for example
Bit combine I think you’re referring to using 1 bit for a status (fuel pump for example), which it can also do. Ecumaster calls this feature “extract bitfield” (I call it ‘bit stuffing’)
If you’re using it to send values that can be done with the aid of a Number function (math channel)
