BMW S50B30 Euro Triggers
I am planning an ecu swap for a S50B30 engine. This was the first of the Euro spec M3 engines. It used a separate ecu and vanos controller.
It has 3 cam sensors, to the OEM ECU one cam sensor on the intake (vanos cam) that is pined to the chain pully so it does not advance, they used this for the home sync.
It then has a 8 tooth exhaust cam trigger and an N+1 trigger for the vanos cam.
I am trying to figure out what cam sensors i need to use do i just need the N+1 or do i need the 1 pulse sync also?
Any help or even a base map will be of help.
We didn’t use the exhaust cam sensor on our S50B30 euro .
did you use both intake cam sensors the 1 tooth for sync and the N+1 for VVT or just the N+1?
Camsync 1 was the phase sensor and camsync 2 is the intake cam position
I think I have a base map but not at home until the weekend .
That makes sense.
If you have a base map you are willing to share that will definitely help out.
Thank you.
were you ever able to dig this up. even just a screen shot of the triggers
I sent details via DM on 29th September ?
I never saw the notice of the DM, i am very sorry.
Thank you very much and this map answered my main question.
Happy new year.
Hello, I have the same problem. Could someone please send me the map? That would help me a lot as well. Thank you.
