Hi Im trying to start bmw m50b25 single vanos full stock engine with ecumaster classic (old model grey box) with ecumaster PnP connector and ecumaster base map for this engine, I check injector signal and coil signal look like is working, I can see RPM, INJECTORS PW, VE, Ignition Angle, Map, TPS… everything looks good but the engine no start… I think is primary trigger setting problem, is my first time work with standalone ecu, I would appreciate any help, thanks.
