Is it possible to have a rotary dial switch for boost map and have a scramble boost on a separate switch?
you can make switch, wich make a signal of maximum rotary switch position
Can you explain how can you make it ?
- You can use a rotary knob for different boost maps.
- You can then separately use a simple momentary switch for a scramble button.
If there is a rotary button out there that also acts as BOTH a dial and can be pressed (momentary) then you can just use that.
Hopefully you follow what I’m saying haha. Sounds a bit confusing I’m sorry.
can you share a map or something to see how its done ? thanks
