Hi I have a rotary switch to control boost, it have 8 positions so 8 boost pressures settings. is it possible to set a switch that instantly goes to the max boost pressure, regarding any position on the rotary switch setting?
The objective is to make a “push to pass” buttom.
some like scramble boost?
Something like that.
Imagine if you have the lowest position on boost settings, lets say it limits the boost for 0.5 bar.
If you press the switch it will ignore the boost limit and will go for the maximum boost you have programed.
I have an 8 position, 1 is minimum, 8 is maximum, pressing that button go straight to the maximum
Any ideia? the ecu is black on V3
