Hello, what are the way to control boost by keyboard 3 states, i found boost correction, its in % but the limit is only 50% witch is nothing:/
The table will take negative values to -100%. Set the base table to your peak target and use the custom table to drop the base table target. Also note there is only 1 overboost limit
weird approach but thanks
