Bosch 4.9 - Emu Black V3
Hello all,
i’m having trouble with my wideband, I have checked all the connections and everything is correct, i have checked conductivity, all good, between WBO heater teriminal i see around 11v, if i connect it the log WBO show NO lambda valid, AFR stuck at 14,7, WPO IP ADC 4,96, WBO RI 2,49, heater DC 0, WBO VS 3,53, WBO IP Meas. 0.
If i put the heater mode to “always on” the lambda become valid, i see temperature and current in WBO IP Meas. Other than that in “fast heat up” or “conservative” nothing happen, I have bought the sensor from the dundle with the EMU Black.
In other Modes than allways on, the WBO heates only if the Engine run.
Thank you for confirm It
