Calculated Rev Match RPM Issue?
Hey all,
Thought I’d try my luck at setting up the rev match feature. I have the gear ratios set up which work well, and I’d like to use the ‘calculated rpm target’ mode.
When testing the rev match target, you can see it is absurdly high, wanting to rev to 5500-7000rpm for a 4->3 downshift going 35-40kmh - when it realistically only needed around 1500-2000rpm to match the revs.
This isn’t something I have used in V2, so it is possible that I am missing an important setting - but does anyone have any leads on what is going on here? Or is this some sort of bug?
(Note: The rev match values I’ve entered are to intentionally prevent the strategy from actually doing anything, so I could collect data on the target rpms)
I will check and let you know
Fixed in version 3.031 (already available for download)
Legend! Will give it a go this weekend. Thanks
