Hey all!
Loaded up V3 last week and noticed the cam signal present channel was cycling constantly between yes and no. It seems to settle on yes when running above roughly 1800rpm. So it appears the cam sensor may not be properly doing it’s job at low rpm.
I’ve gone over my trigger settings and they all match what I had in V2 (which didn’t have this issue). I have also tried a big mix of different pullup/pulldown resistors and input filters on both the primary and secondary triggers. Switching the trigger edge did not help either.
Does anyone have any ideas on what could be causing this? What is this telling me about how the cam sensor is operating? (given the engine operation remains synchronised throughout - without trigger errors)
Much appreciated!
Map/Log/Scope:
https://drive.google.com/drive/folders/1-E5FZ4n8BXXjX6D_tuwSWhLwgTepFgB3?usp=sharing
