Hello all,
I’m using a Can Switch Board V3 on a Link ECU G4X (because Link Ecu handle the Oil metering Pump) on a Mazda RX7 FD3s
All the classic Inputs are used, so I added a CAN Switch Board V3 to plug 2x EGT sensor on it
The problem is… no CAN informations report to the Link ECU
I already asked the Link Forum, he checked and told me everything was fine in my setup (There is already a setup file for the Switch Board V3 in the Link software)
He tried my tune on a bench and send voltage in Can An1 and it is working, so I guess my problem come from my switch board
"Your ECU config is correct now as far as I can see. I tested on the bench in an ecu using the same old firmware version you are running, sending 00FF on ID 0x640, the ecu correctly receives 0.255V on CAN AN1. "
The switch board is turning on (orange led), no problem here
I jumped the 5V in the Analog input 1 to make sure the problem doesn’t come from somewhere else (EGT sensor etc)
But the CAN AN 1 input still report 0V
Did I am missing something ? Except the wire connection I touched nothing on the switch board, ID1/2/3 and Speed Jumper are still open, same for the termination, still open
I don’t have the Light Client software because I have nothing to connect the “CAN to USB, but the manual said :
Jumper ID3 is responsible for entering
compatibility mode. If it is open then
CAN Switch Board is configurable
using Light Client (speed, base ID,
rotary switch configuration) software
and the device sends data using new
V3 data format. The default speed is
500 kbps and base ID is 0x640.
When the ID3 jumper is closed with a
solder joint, the device enters
backward compatibility mode and can
be configured using jumpers.”
So the switch board should be in the standard V3 format right ?
Is it because of the 120 ohm termination still open ?
Or maybe I can’t do without the software with ID3 open ?
Thanks for your support !
