Switchboard V3 CAN Error / Orange LED flashing
i have a problem with my new Ecumaster Can Switchboard V3.
As soon as i connect it to 12V, the orange LED starts flashing.
When i then connect the CAN H and CAN L Connectors, the whole CAN Bus of the Car goes into Error and nothing works anymore. I also Can’t connect with Light Client to any of the devices anymore.
My CAN Network has 120 Ohm Resistors on both ends and is otherwise working fine with the other CAN Devices(ADU, EMU, PMU,…)
Is the Switchboard faulty or could it be some kind of other reason?
Thanks,
Bernd
you need to set can bus rate correct for your vehicle. use lite client for that
Thanks a lot, that was an easy fix. just had to disconnect all other devices from the CAN Bus to be able to do that👍
