When building a CAN output, what does the “cycle” frequency do? I have plenty of CAN outputs for data that is working fine, but I’m havin issues with 1 set of outputs to control some exterior lights.
These Ights are controlled by a Canbus Arduino board. I’m sending a 1 or 0 (based on a status variable) however, when I set 100hz, my lighta cycle on/off, a lower hz cycles slower.
So I’m assuming the cycle is doing something odd.
I can change the code on the Arduino, but trying to understand how the “cycle” works so Imcan duplicate it on my test bench (another Arduino board) because I don’t have the car at my house.
