Change name of Custom Temperature Sensor
I would like to configure a Custom Temperature to use a name not in the existing list. I currently have “Power Steering Temperature” selected for Custom temp. 1, but I would like to use “Crankcase temperature” instead. It appears I can edit the version3_062.xml file to change the name property in paramlists “customTermperatureSensor” and “pwm2AxisType” to accomplish this, but I don’t think I should be mucking about with the system XML file. Is there an acceptable alternative? Maybe a supported interface to edit the custom name fields?
TIA, Steve
