Custom input sensor definition
Still a complete newbie in the EMU world.
It seems to me the software does not allow to define a custom input sensor in terms of assigning a custom name.
I’m looking for probing the intecooling water temperature and, since there is no specific preset field for that, I would need to use something else and remember the name.
It would be a nice software feature to have
Define a custom table in the project tree using the ‘Resources Analog X Voltage’ channel for X-axis. Name your table as you wish. It will be your calibration table
To change pull-resistor, assign (just for a configuration purpose) the chosen input to whatever sensor, change the pull-setting and then unassign it. Pull-setting will be remembered.
This solution is not ideal (you cannot define voltage filtering for example) but it should do the job.
