Changing units of analog inputs to bar/celsius
Hi dear community,
is it possible to set the physicall values for the pressure and temperature sensors connected to the analog inputs to bar or celsius, so that this units are displayed inside the tune display or gauges that way?
I connected
oil temp to Analog In #1
oil pressure to Analog In #2
fuel pressure to Analog In #3
Inside the sensor wizards i marked the emu sensor + the temp or pressure calibration for the sensor. When i want to change the unit from voltage to celsus or bar inside the gauge properties nothing happens.
Only thing is that i can choose “engine oil temp” and so on inside the tune display and gauges additional to analog #1, #2 or #3. These items have the correct units then, but is that the way to go or do i have to do something else?
Anyone?
Maybe the units of the Analog Inputs cannot be changed and it is meant like that? An if the user wants to see it in bar/celsius he has to look at the engine oil temp/pressure channels? So it is as specified?
Analog inputs shows its natural unit (V). If you connect any sensor to EMU, you want to have diagnostic, as well as proper sensor calibration. So you need to select the sensor, assing the analog input and then you will get proper values.
