Analog precision input
Hello
On an emu pro8 can we configure classic temperature sensors (Bosch style for example) on the 4 analog precision inputs?
Apparently they are only dedicated to egt?
On the software they are not offered to me when I want to set a temperature.
Thank you
You can use them with a little workaround.
The following thread will help:
Currently, they can be used for EGT or switch inputs.
We have plans to expand the functionality.
We want to add the possibility of using thermocouples connected to precision inputs as coolant temperature sensors and any other temperature sensors in the software, as well as a 0-5 V measurement range, so it’s also possible to use thermistors.
We will bump the priority for those features.
Hello
I use the Bosch temperature sensor on different analog inputs, I did not understand the calibration according to the resistance imposed by the INPUT on emupro8.
Sensor is 0280130026 bosch
Can you give me help for math?
Analog 1-16 has different pull up resistor.
King regards
