Hello everyone,
I’m looking for an experienced ECUMaster EMU Classic tuner who can help me optimize the calibration of my Citroën Saxo / Peugeot 106 1.6 16V TU5JP4 naturally aspirated race engine.
ENGINE SPECIFICATIONS
Bottom end:
TU5JP4 1.6 16V engine
Wössner forged pistons, 79.00 mm
Forged H-beam connecting rods
Compression ratio: 12.3:1
Squish clearance: approximately 1.0–1.1 mm
MLS head gasket: 0.61 mm
Cylinder head and camshafts:
Fully ported cylinder head
Mechanical valve lifters
Valve clearance: 0.25 mm intake / 0.25 mm exhaust
Intake camshaft lift: 11.7 mm
Exhaust camshaft lift: approximately 11.0–11.5 mm
Camshaft lobe separation angle: approximately 105°
Intake system:
Individual throttle bodies from Suzuki GSX-R1000 K4
Throttle diameter: 37 mm
Intake runners: 38.8 mm internal diameter, 108 mm length
50 mm velocity stacks
Custom airbox
Ducati 330 cc injectors
Exhaust system:
Custom 4-2-1 exhaust manifold
Primary pipes: 38 mm diameter
Secondary pipes: 42 mm diameter
Final collector: 60 mm diameter
ECU and electronics:
60-2 crank trigger
Single-tooth camshaft trigger
Audi R8 ignition coils
Firing order: 1-3-4-2
TPS-based fuel mapping
External LSU 4.9 wideband controller
100 RON gasoline
DYNO RESULTS
The engine previously produced approximately:
200 HP
18.5 kgm torque
Operating range up to approximately 8,000 RPM
WHAT I NEED HELP WITH
I would like to improve:
Fuel mapping and AFR targets
Ignition timing calibration
Idle stability at approximately 1,400–1,600 RPM
Torque and power delivery between 7,000 and 8,000 RPM
Overall drivability and safe engine operation
During a previous dyno run, the engine experienced an oil-pressure warning and metallic debris was subsequently found in the oil. Mechanical and lubrication-system integrity must therefore be verified before further high-RPM testing.
I have the current EMU Classic calibration file and can provide datalogs for review.
I’m looking for someone experienced with highly modified naturally aspirated engines and ECUMaster EMU Classic who would be willing to review my calibration and suggest improvements.
Thank you very much for your help!
