Coils are connected properly, ouput testing is working but no spark on cranking
Hello guys, am currently trying to make my teams fazer 600 engine to work but i have zero spark.
First of all our wiring is correct so crankshaft position sensor and coils are working perfectly, also when i test the ouputs with the spark plugs outside the engine and grounded with the engine, we have very strong spark but when i am cranking the engine we have rpm , trigger scope (which does not have errors, isnt the best 24-1 that you can see but it can work) and no spark at the spark plug. I have tried everything at the software and nothing works, i was wondering if ecu master does not let you start up the engine internaly if you scope isnt on point or something like that for safety reasons or maybe i have something wrong in the setup that blocks the cranking spark. I am submiting my project as well if anyone has any idea whats going on.
thank you for your time any help would be much appreciated
star.emub (145.7 KB)
You have 40 revolutions of start delay turned on. Try it with 0.
starv2.emub (146.2 KB) Thank you for the suggestion but it didnt work, i have twicked some other setting and now i am getting spark only at cylinders 1,4. 2,3 dont have any sparks. When I change the revs to 0 i dont have spark at all.
