On the pinout it’s stating the regular pin-out for the EMU Black but since it’s a PNP I don’t want to mess up the original wiring loom
. I assume on the factory wiring to the lambda is being re-used but I want to know for sure since I am supposed to add a resistor to it. Anyone has done this and know’s if im correct and what factory lambda is being used? Bank 1 or Bank 2 pre-cat?
And as for the resistor, adding it to the lambda itself in the middle of the line basically with a small extension cord which I need anyways is fine?
With kind regards,
Joey
