Hiya, I have been using Black V2 on my supercharged TT VR6 for a while & wanted to change to V3 so I have merged data from the Work In Progress BUB file with my converted V2 map.
The car fires up easily & seems to run on all 6 but dies almost straight away…unless I un plug Cam 2 solenoid then it will run ok, idle, rev up etc & sounds relatively good.
I am no expert in this field so any help would be greatfully recieved. I have tried changing Cam 1 & 2 parameters but getting nowhere.
It is a R32 BUB PNP with an eaton M112 Blower running a 2.5mm Head Spacer, forgot to metion that.
Log file & Scope file attached in the hope someone can spot what is wrong, TIA, John.
test log 1.emublog3 (2.4 MB)
scope test 1.emubscp3 (632 Bytes)
v3 Test.emub3 (70.3 KB)
