Hi All,
Is there any plan to add the ability to customize smart grids in the future? Like the ability to hide items in a grid or make your own custom smart grid? I know we can have custom lists of variable with the custom text logs, but whenever I need to change a setting or calibrate a sensor like throttle position I have to dig through the smart grids and this can be a bit clunky and waste time with all the levels you have to step through. Like I’m only using maybe 1/3 of the sensors available, so it would make sense for me to either hide the ones I don’t use or make a custom smart grid in a custom desktop that has only what I need. And the premade smartgrids for every category aren’t a great solution either since it only moves you down one level in the grid, so there are still way too many choices.
I also think adding the ability to add individual settings and values from the smart grid to desktops as panels might be a good feature too. This is basically just another way of going about the above feature request, but several other tuning programs do it this way and I like it since there might be certain things you change frequently that you would want to break out into tiles on a desktop like say rev limit, fuel pressure target, or throttle position 0% and 100% voltage.
I think these features would be a really great quality of life improvement to the client. I know the time save from customizing these things might not seem like much, but when you are paying for dyno time everything helps. Also I think any time you can remove clutter from your workflow is a huge win.
Thank you!
-Spencer
