Hi
I need a little help setting up datamaster, as you can see above I have a error in ecu.flag5 but how do I find what is actual causing this error?
Hi
Not really enough information provided to answer this. I’ll try but it’ll be vague without having access to your logs and calibration files etc.
I would look at what data the ecu is sending on that channel. Are you pulling data from an ADU, PMU or ecu?
