CAN BUS messaging issue
Could someone have a quick look at this and see what I’ve done wrong. I’ve ran out of knowledge!
I’m set up my ECUmaster PMU24 to send two frames of data to my G4x. Link is set to receive on 1200dec and +1 for the second frame.
The first frame works although the currents values could ideally be set to work to 1dp instead of just showing whole numbers but I can’t see how I would be able to do that.
The items from frame two don’t respond at all. As a sanity check I’ve copied one of the parameters from frame two to a spare slot in frame one and it works as expected so I’m assuming it’s something to do with my numbering and isn’t an issue with CAN bus number, Bus speed etc
https://drive.google.com/file/d/1yjmCl6DKYRJmrFN70Nk8E6ozfR23WBD7/view?usp=drive_link.
Any help is appreciated
Files are not accessible.
You have to change the access rights.
Sorry, they should be accessible now
