DBW wiring ECU master classic
Hello im installing my first standalone ECU in my Volvo 740 with B5234T. I have som questions about wiring the the throttle body
I use ECU master classic with the DBW modul and the later 06 v70 Throttle body im wondering what outputs from the ECU i should use to control the throtle body Pot1/TPS1 and Pot2/TPS2? I allredy have 5v+, singnal ground, engine + and engine ground to the throttle body
Were you able to figure it out? Im in the same boat as you
