I recently added DBW (Bosch 0 280 750 156)to my build and a Lexus pps. However when trying to adapt the tb on v2 I keep getting the no movement error check wiring.
I tried to adapt on v3 and the emu is able to populate all tables as well as idle and work ok, although it took a bit of time to figure out how to populate the ops and tps tables.
All sensors are registered and hbridge a&b work on v3 output test but not on v2 unless I check the BMW itb box in dbw parameters.
Any help is appreciated, the wiring is brand new and so is the ops and tb.
As far as i remember, the polarity of wiring is more important in v2. Please make sure all the signals, as well as check signals are correctly wired as the old v2 expects. (especially + and - and second sensor is half of first and so on)
In v3 the calibration tool got way better and can figure that stuff out. (or you set it easily yourself)
At least that’s what I remember. Correct me if I’m wrong.
And please add your v3 and v2 files.
Thanks for the reply, I was able to get it working seems like the pps were giving two signals with an error too high for v2 to manage, but disabling the check signal did the trick.
